01 cummins loping and jerking while driving
Old May 19, 2012 | 04:57 PM
6inarow-01's Avatar
Default 01 cummins loping and jerking while driving
Hey guys new to diesels and need some help. I have an 01 cummins 4x4 auto with egde juice w/attuide, manual lift pump, new injector pump, new apps sensor, new cam shaft position sensor, new batterys And alternator.... Thats all I can think of now. The truck is loping in park but not drive and while driving it wants to start jerking/jumping even with o/d off.... Any help would be great.... Thanks!!
Old May 19, 2012 | 08:22 PM
RanchhandTCR's Avatar
Disconnect your chip and see if it keeps doing it, if its not the chip, make sure you dont have any air in the fuel lines.... and check your fuel filter....
Old May 19, 2012 | 08:42 PM
6inarow-01's Avatar
I did that thinking it was the problem but when it wasn't I hooked it back up...I was having problems with the tank holding pressure and poped the release thing in it and solved that problem...how how do I bleed the line?
Srry just recently replaced fuel filter
Last edited by 6inarow-01; May 19, 2012 at 08:42 PM. Reason: Automerged Doublepost
Old May 19, 2012 | 10:07 PM
Whit's Avatar
Site Mascot
watch yer RPM gauge when its doing it...........if it drops off then its the crsnk position sensor losing signal
Old May 19, 2012 | 11:12 PM
6inarow-01's Avatar
I bought one thing that was it but it doesn't have 1. There is a plate over where it's suppose to go... Did some research and found out they did away with starting in 01 and went to cam shaft position sensor.... So I replaced it still no luck
Old May 20, 2012 | 11:58 AM
Can you get ahold of a OBDII and see if you can pull anycodes, you can still have codes with no lights.... if your PCM is bad you can have troubles....
Old May 20, 2012 | 12:25 PM
6inarow-01's Avatar
I'm getting a p0122 code when I do the key thing but the apps sensor is less than a year old .... I was leaning toward the PCM being bad... Cause the turbo cool down timer only works sometimes.... If truck is loping it doesn't work and truck shuts str8 off
Old May 20, 2012 | 08:29 PM
empty wallet's Avatar
0122 is apps voltage, means you need to adjust it, doesn't mean sensor is bad. I highly doubt the pcm is bad. You need to access a good scanner like a snap-on solus or something, where you can monitor everything while the truck is running and even perform tests on certain components and sensors.
Old May 20, 2012 | 08:33 PM
6inarow-01's Avatar
Would me bypassing the ECM form the apps sensor and going str8 to the PCM give me that code?.... Going to put it back stock and see if code goes away... I did it because it said it would do away with 4th hunt but ... Still having that problem ...
Old May 20, 2012 | 08:45 PM
I've never heard of anybody doing that. You need to set the voltage on the sensor per the spec on the back of the apps housing, and I'd put it all back stock. I've also never heard of anything apps related making a truck lope.
