Brakes LOCKED up ?
Old May 18, 2012 | 07:21 PM
billu's Avatar
Default Brakes LOCKED up ?
All 4 brakes started dragging today after driving to work 20 miles. I did not notice then that all 4 were sticking just noticed smoke from the right rear. I replaced that caliper guessing that that was the problem, but when i arrived at home after the repair again all ok until last 5 miles - all 4 brakes dragging. No brake warning lights, pedal is full at the top - a little to close to the top from normal conditions. What can i do to diagnose the problem? Power steering is normal and there is sufficient brake & PS fluid.
Old May 19, 2012 | 08:11 PM
tiremann9669's Avatar
Try replacing your rubber brake hoses. I've seen it where they swell up inside and won't let the fluid back through.
Old May 22, 2012 | 12:12 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Hmmm. I have never seen that before... ABS issue maybe. Or maybe a hydroboost/ master cylinder issue??
Old May 23, 2012 | 06:31 PM
MRaynor's Avatar
I agree with 1AMATT, I had this happen on a Dodge van when it developed an ABS problem. It was a company truck, so I couldn't tell you exactly what it was.
Old May 24, 2012 | 05:54 PM
1AMatt's Avatar
Any luck on the problem yet?
Old Jun 5, 2012 | 08:11 PM
billu's Avatar
thanks - after replacing the power booster i have came to the realization that my original problem was caused by adding power steering fluid to the brake system. I am beside myself and cant believe i did this and not catch it right away. I am in the process of replacing the master cylinder and tank but wonder if the oil is in the lines how can i remove it? can i flush any type of cleaning fluid first before bleeding the brake system. I was going to clean the brake resirvoir until i noticed that the entire inside surface is coated with oil like film so i decided to get a new one instead of cleaning this one. Any help at this point would be greatly appreciated as i am very upset i could be so careless.
Radioking1777
Jun 9, 2015 04:13 AM
thatdude38
May 9, 2015 12:21 PM
kryz9903
May 4, 2015 05:00 AM
12valvedually96
Mar 17, 2015 06:00 PM
1MooseheadPlease
Oct 13, 2014 05:33 AM
