TC Lockup Switch
Not sure about a 2006 but on my 2005. I tapped the #7 wire from the ROUND plug on the tranny. (plug does have very small numbers showing which is #7). From that tapped wire, I ran it to a switch in the cab. I then went from the switch to a common ground.
So when you hit the switch, it would lock my TC. Turned switch off and tranny worked like normal.
Hope that helps.
Hope that helps.
I'm totally clueless on this sort of thing and I have a manual so I'm pretty sure it doesn't even apply to me, but can someone explain this whole concept to me, cause I hear about it all the time and don't have a clue whats going on.
rstrange1996
Sep 22, 2015 01:25 PM
IslanderXJ
Dec 17, 2014 04:14 PM
06 3500 CTD. Looking for the info to lockup the tc with a switch. Grounding what wire?
