cold air only on drivers side
Old May 18, 2012 | 04:46 PM
jones's Avatar
Default cold air only on drivers side
i have a 2004.5 dodge cummings and i have really cold air only on the drivers side i didnt know if anybody has had this probly or if there is a easy waqy to fix it for now i heard it was the blend door or the blend door motor need some help
Old May 18, 2012 | 09:15 PM
MurphyStrut's Avatar
Try putting a good charge on the system, worked for me?
Old May 18, 2012 | 10:41 PM
jones's Avatar
i heard of that but i wouldnt think i would be getting any cold out at all i have air comming out but its warm but all the vents work fine as far as switching from the floor to defrost
Old May 18, 2012 | 10:44 PM
TheOtherNick's Avatar
I would pull the controls out of the dash and back sure the temp selector is working for the passenger side assuming you have dual controls. If it is I would be leaning towards the passenger side blend door.
Old May 19, 2012 | 12:23 PM
jones's Avatar
thanks guys i dont have duel controles as far as the passenger and drivers side i thought if it was the blend door the rest of the controles wouldnt work right defrost and everything works fine
Old May 20, 2012 | 12:38 AM
Bigred7.3's Avatar
ur system is low on charge take it to an a/c shop n.have it chatged mine did the same thing had it charged n blows cold on both sides again
Old Jun 20, 2012 | 10:47 PM
bookum1's Avatar
ditto... I had the same problem. Took it to a mechanic friend and he charged the system and now it works great.
Old Jun 21, 2012 | 07:47 AM
dixierebel0213's Avatar
i do about three a day at dealer try charge first its cheaper and if you arent leaking you wont waste any freon and when they get low they blow cold driver side, warm passenger. but ive pulled many dashes especially for recirc door breaking and its very possible that a blend door broke, its normally the clip that connects the motor to the door breaks an ear, motor over travels then bust out of door. it will make noise but wont actually turn door. good news is i can pull dash in about 30 mins so its not horrible if you have to
hoeky22
Jan 2, 2015 04:54 PM
Project_5.9diesel
Dec 11, 2014 09:41 PM
12vbomber
Nov 4, 2014 10:04 PM
petew
Oct 25, 2014 09:29 PM
