what next
Old May 18, 2012 | 10:46 AM
Cummins1994's Avatar
Default what next
what should i do next guys current mods r in my sig
Old May 18, 2012 | 12:37 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Have you upgraded you transmission yet?
Old May 18, 2012 | 03:26 PM
not sure exactly what was done to it but its jst over a year old and the guy i bought it from said it was upgraded and everything else was stock before i got it
Old May 22, 2012 | 02:28 PM
well guess it wasnt to good cuz i toasted it nut luckily it had a good warranty but this one is gona get a better valve body and a billlet single disk torque converter
Old May 22, 2012 | 02:37 PM
Eddiebuntain's Avatar
Guess you answered your own question
Personally I like the heavy duty 1/4" plate steel bumpers, but that's your call
Last edited by Eddiebuntain; May 22, 2012 at 02:37 PM. Reason: Automerged Doublepost
Old May 22, 2012 | 04:05 PM
1AMatt's Avatar
That stinks... get it built up then you can do whatever you'd like to the motor
Old May 23, 2012 | 12:33 AM
well it wasnt toasted it was some sensor bullshit il know more wen i go back to tlk to the shop tmrw but watevr it was did some damage cuz fluid smelled burnt but im still gona build the tranny up now but i think after that injectors r next on the list im think some 5x12's does that snd rite?
Old May 23, 2012 | 05:28 PM
tiremann9669's Avatar
Guages
Old May 23, 2012 | 08:23 PM
ricet07's Avatar
Everything depends on what you want to get out of the truck and what you will be using it for. Typical checklist for mods-->
Gauges (pyro, boost, trans temp for auto and or fuel pressure gauge)
Trans work (TC and valve body for auto, clutch and 5th gear nut fix for nv4500)
KDP
Timing (16* is pretty common)
BHAF
Fuel Plate (Grind your own to your liking)
AFC (tune your AFC as you bring on fuel so your not clouding out the world)
Boost Elbow
Injectors/Springs (Plan on running stock charger then 5x.12's, if you have the right tools and the injectors are already out then it would be a good time to do 60lb springs)
GSK
Lift Pump
Looks like you have some of them knocked out of the way and a lift pump is not a big deal with those mods unless yours is on its way out.
Old May 24, 2012 | 11:07 PM
Cordova2013-12 Valve's Avatar
Simple and $0 to do. Turn your barrels all the way clockwise
