low boost
Old May 18, 2012 | 08:25 AM
chen's Avatar
Default low boost
hi i just recently installed gauges and a 5 fuel plate. the highest my boost will get to is like ten or twelve. i looked at the boost line for the gauge and its kinked in three places the egts are normal and it feels like it still has good power. do you guys think the kinked line would cause the gauge to read so far off?
Old May 18, 2012 | 07:01 PM
kurtimas13's Avatar
definitely would be your problem.
Old May 20, 2012 | 08:15 AM
chen's Avatar
alright thanks any suggestions on what kind of hose i should replace it with ?
Old May 20, 2012 | 08:57 AM
daveO's Avatar
I would see if the company that makes your gauge has any replacements available.
Old May 20, 2012 | 09:12 AM
Whit's Avatar
Site Mascot
tygon tubing works best and easily found in the stores
if yer boost is still low make sure to check every boot from the charger out..................the clamps always are loose
Old May 20, 2012 | 09:41 AM
chen's Avatar
okay so im assuming ill need to get new pressure fittings to right?
could i find tygon tubing at oreillys or napa
Old May 20, 2012 | 09:53 AM
94cummins12v's Avatar
just get the black nylon DOT air brake like from napa that all ive ever used with no issues its more rigid than the clear stuff its available at napa
Old May 20, 2012 | 12:55 PM
chen's Avatar
alright so i just bought the air brake line from napa installed it took it for a test run boost gauge still wont go above like 8psi??? any thoughts?
Old May 20, 2012 | 03:21 PM
Whit's Avatar
Site Mascot
tighten all yer clamps on the boots from the chargeer to interccoler in and out then also to the intake horn........you have a leak
if it still shows no boost then yer wastegate is leaking or partially stuck open
Old May 20, 2012 | 05:49 PM
Cordova2013-12 Valve's Avatar
Imma chime in on this thread instead of starting a new one. I just installed a boost elbow and i didnt notice any significant difference in boost once spooled and on spool up. Should I? Or does the elbow not really do much for boost..
