need some ideas. replacing injection pump
Old May 16, 2012 | 08:46 PM
Dirt_Diver's Avatar
Default need some ideas. replacing injection pump
Dad wants to go back with a hott rod pump. Already have a fass system. Is there any ideas on what else to change? Thanks?
Old May 16, 2012 | 09:52 PM
empty wallet's Avatar
What else to change as far as what? just go s.o vp
Old May 19, 2012 | 11:12 AM
Dirt_Diver's Avatar
I hes already ordered the pump. But as far as replacing. Is there any electronics you hace to replace? Also is there anything that has to be readjusted?
Old May 19, 2012 | 11:23 AM
Nope, all the pumps electronics are already in it. But you will need the puller to get the pump off the gear.
Old May 19, 2012 | 11:51 AM
Dirt_Diver's Avatar
Ok thanks for the heads up. Now, what about takin the pump out and back in. I know the gear has to be on 12' o'clock. Any other advice
Old May 19, 2012 | 12:05 PM
yeah make sure the keyway is facing 12:00 like you said is important, the nut between the pump and the block is fun but other then that it's all fairly easy stuff, once you get all the **** moved out of your way
Old May 19, 2012 | 12:08 PM
Dirt_Diver's Avatar
Thanks for the advice!!
Old May 21, 2012 | 08:47 AM
boosted's Avatar
Why did you choose the HRVP? If you have a good chip on the truck you are not going to gain anything with it except spending more money for it..
Old May 21, 2012 | 10:51 PM
BarryB's Avatar
I bought the puller for the pump gear. but the cheap steering wheel puller worked fine for me, when I was in a pinch. only real reason to keep the keyway at 12:00 is so the key doesn't fall into the timing gear. alot of extra work to get it if it fell inside. what I did on mine was ping punch the key so it flared out some. That way its fits snuggly into the keyway on the pump. You would have to really knock into something pretty hard to have knocked it out during installation.
Old May 23, 2012 | 02:11 PM
Dirt_Diver's Avatar
The reason he went with a HRVP, bc he wanted the extra power and everyone around town kinda push him into. But hes got that, a edge juice with attitude and 90hp injectors. I need to test the injectiors. Also does the hvrp have any fuel milage?
nelly559
Feb 17, 2015 06:49 PM
moneypitk5
Feb 12, 2015 11:01 AM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
abuchanan250
Oct 6, 2014 09:56 PM
