Performance mods. Any and all
Old May 16, 2012 | 05:21 PM
Franimal's Avatar
Default Performance mods. Any and all
I have a 97 4wd 5 spd manual dodge diesel. Clutch slave cylinder feels like its going as sometimes when I put the clutch in it sinks right to the floor. But that's beside the point. I was thinking about a 6 spd tranny swap, a new clutch, maybe a new turbo, cold air intake, anything. I need suggestions of brands for parts and recomended shops for work to be done. I live in Sicamous B.C Canada. I use the truck for running hot shot up in the Riggs and I also do a fair amount of off roading. Any and all help would be appreciated.
Old May 17, 2012 | 12:57 PM
1AMatt's Avatar
Site Sponsor - 1aauto
You can go as mild/wild as you want with HP on a 12v.... But first things first you need basics. Upgraded clutch like you said, gauges, lift pump, and if you plan on running a lot of boost you'll need studs and a new head gasket!
Old May 27, 2012 | 12:17 AM
Cordova2013-12 Valve's Avatar
Can you bolt up an nv5600 right to a 2nd gen 12 valve with an nv4500 stock?
Old May 29, 2012 | 11:23 AM
94 12valve's Avatar
you will need a new bellhousing, shifter, clutch, and possibly a new cross member depending on how late of a 97 he has
