3rd gen hot pipe for my twins
Old May 15, 2012 | 09:08 PM
cumminscwby's Avatar
Default 3rd gen hot pipe for my twins
I have all the parts for my twin setup except intake tube and air filter. I got a good deal on a 3rd gen hot pipe. Does anybody know if it will line up right or I will I need spacers? Might be a hard question to answer but maybe someone can answer before I tear my truck down. Thanks fellas.
Old May 15, 2012 | 09:45 PM
cummin_un_glued's Avatar
FormerVendor
thats going to depend on which primary turbo mount your using also is the hotpipe made to fit a stock 3rd gen charger or is it hx40 style so that it will fit your S300?
Old May 15, 2012 | 10:42 PM
Its hx40 style. I used the primary mount from source automotive.
Last edited by cumminscwby; May 15, 2012 at 10:57 PM. Reason: Automerged Doublepost
Old May 15, 2012 | 11:41 PM
FormerVendor
which primary mount did you use tho the second gen or 3rd gen
Old May 16, 2012 | 12:05 AM
It just says for 24v. I might just have to find out during the install
Old May 16, 2012 | 09:18 AM
FormerVendor
The 3rd gen mount sits in a different spot then the 24v. Im afraid your pipe wont line up.
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old May 16, 2012 | 10:14 AM
Think i can make it work with a couple spacers?
Old May 16, 2012 | 12:49 PM
FormerVendor
If im thinking right the 3rd gen sits closer to the block. I think you will have to cut and weld
Old May 16, 2012 | 10:10 PM
I have the equipment to do that so I can fix that. Thanks man for your help
Old May 17, 2012 | 12:09 AM
FormerVendor
no prob
Torkjunky
Nov 20, 2018 08:46 PM
CHAMP31707
For Sale
Jun 1, 2015 04:03 PM
CGwill
Jan 26, 2015 02:10 AM
