Can't get my idle down
Old May 15, 2012 | 01:47 PM
1stgen12valve's Avatar
cool Can't get my idle down
So I had to replace my pushrod cover last weekend and figured since I had the pump out I would tinker with it. I had already moved the timing up ran the screw into the collar and moved the fuel pin. I took off the collar on the fuel screw and ran it in alittle more. that made a world of differance I was getting smoke at full throttle and the truck really came alive, but it was very close to running away so I turned the screw in half a turn and that seemed to be the sweet spot. However the idle was crazy high I turn the idle screw down some and not much diffreance. I turned down again and still pretty high. I bumped the timing back alittle and that didnt help I really dont want to turn the screw back out. Is ther anything else i can do.
Old May 15, 2012 | 08:22 PM
welderboy250's Avatar
Reindex lever on shaft
Old May 15, 2012 | 08:30 PM
BC847's Avatar
Lengthen the rod that connects the injection pump's fuel lever to the throttle bellcrank (the one that looks like a tiny tie-rod). Just screw it out till the idle drops where you want it.
Old May 15, 2012 | 09:41 PM
good idea why didnt I think of that
Old May 15, 2012 | 10:00 PM
Rusty89Cummins's Avatar
if thats not enough you'll have to just back the fuel skrew out a little more.
Old May 15, 2012 | 10:30 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i have saw fellers bend the plate where the idle screw hits.
Old May 16, 2012 | 11:51 AM
moparbubbabt59l's Avatar
Take out the screw all together lengthen the throttle linkage with the ball stud ends and move the stud to the other hole
Sent from my DROIDX
Old May 16, 2012 | 02:49 PM
db Zac's Avatar
is the idle stop on the leaver touching the casting yet? What I did was put both jam nuts on the back of the idle stop screw instead of having one at the front and once at the back.
MechanicalDiesel
Aug 11, 2015 08:14 PM
jordanokc
Feb 8, 2015 03:59 PM
Mc Merc
Dec 16, 2014 06:59 AM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
