What should I do? Help needed!
Old May 15, 2012 | 01:28 AM
jeepin13's Avatar
Default What should I do? Help needed!
Driving to work Friday night, I got a CEL. Parked the truck and checked the code, P0148. The truck had quite a bit of fuel in the oil and had fuel coming out of the blow by tube. I had the truck towed home andstarted pulling it apart. As I began to loosen the injector hold downs, I noticed a loose hold down. I thought to my self, maybe I already hit that one and continued to the next one. I found several more loose. Could this be causing my issue with the CEL and fuel in the oil? Everything is still apart. Should I have the injectors tested since I am this far? Should I just retorque the hold downs and see if my problem is gone? How much does a shop charge to test a set of injectors?
Thanks,
Chris
Old May 15, 2012 | 12:58 PM
justinram's Avatar
Since you are to this point, I would go ahead and have them inspected. It is going to save you time if that is your problem. Then I would retorque everything and see how she is running. When I start breaking it down, I check everything I can so, I dont have to go back and tear the same place down again. Good Luck.
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
Strictly Diesel
Strictly Diesel
Jun 30, 2015 06:48 PM
Crwln73
Jun 24, 2015 05:14 PM
klein444
Jun 20, 2015 11:48 PM
SixSpeed
Jan 11, 2015 01:41 AM
