Stripped banjo bolt on the injector
Old May 14, 2012 | 08:13 PM
smokin6bt's Avatar
Default Stripped banjo bolt on the injector
So i was putting in new injectors and i stripped the banjo bolt goin into the injector on the 6 cylinder. Im thinkin i either put the stockers back in with a new banjo bolt or re tap the injector and put in a bigger banjo bolt. Ideas suggestiins?!
Old May 14, 2012 | 10:23 PM
Whit's Avatar
Site Mascot
pull the banjo and check the threads ................did the strip off the banjo or the injector
Old May 20, 2012 | 03:47 PM
smokin6bt's Avatar
so the banjo bolt was a total loss and the injector only has threads at the end of the hole. Im thinking of putting in a helicoil. Just dont know if it will seal properly but i figure it cant hurt to try.
Old May 20, 2012 | 03:50 PM
Whit's Avatar
Site Mascot
thats just a few inch pounds of torque requirment there.....how did this happen??
I would get a new banjo and try to make it work with the injector as is, maybe with a bit of lock tite
Old May 20, 2012 | 04:29 PM
smokin6bt's Avatar
I messed up. Thought i just hit a hard spot in the threads so i over did it. I put the stockers back in till i get the one fixed
Old May 20, 2012 | 04:35 PM
Whit's Avatar
Site Mascot
truck forums here..watch langauge please
Old May 20, 2012 | 05:56 PM
Red_Rattler's Avatar
High Tech Redneck
Or you can just buy mine...
Vycan
8
May 11, 2015 10:46 AM
Dkolanski06
Apr 23, 2015 09:32 AM
2ndcummins1
Mar 9, 2015 10:01 AM
amztroyer
5.9L 24V Performance
Mar 5, 2015 05:02 PM
NiNjAassasin545
Dec 2, 2014 11:40 PM
