HEADGASKET?
Old May 15, 2012 | 09:39 AM
sweetv8s10's Avatar
Default HEADGASKET?
I changed my fuel plate today and it raised my boost a little and now my headgasket is leaking on the passenger side but my boost never got over 30psi so do u think it was the boost or just a bad headgasket and if I retorque the headbolts will it help?
ANYONE?
Last edited by sweetv8s10; May 15, 2012 at 09:39 AM. Reason: Automerged Doublepost
Old May 15, 2012 | 01:00 PM
captain_stabbin's Avatar
if its blown, then its done
Old May 15, 2012 | 11:01 PM
sweetv8s10's Avatar
I broke a head bolt on the passenger side what if I put another bolt back in it?
Old May 15, 2012 | 11:06 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i have seen this happen on my sons truck. i replaced the head bolt and no more water leak. keep in mind no comp was ever leaking only coolant
Old May 16, 2012 | 12:30 AM
sweetv8s10's Avatar
What is no comp?
Old May 16, 2012 | 06:10 AM
huricane's Avatar
compression
Old May 16, 2012 | 08:54 AM
sweetv8s10's Avatar
oh ok thanks what is the torque specs for the head bolts?
Old May 18, 2012 | 02:22 AM
kurtimas13's Avatar
replace headgasket and re torque headbolts to spec + 50 extra torque i believe is what you are supposed to do when re using stock headbolts. try and keep the bolts matched to which spot you originally removed them from.
Old May 18, 2012 | 08:54 AM
sweetv8s10's Avatar
What are the torque specs?
Old May 20, 2012 | 01:51 AM
sweetv8s10's Avatar
So no one knows the torque specs?
