Injector prob. Need help
Old May 14, 2012 | 10:19 AM
Short cummins's Avatar
Default Injector prob. Need help
Ok to start off with, I'm not a cummins fan. I prefer and own power stroke. But I picked the for a great price. Or so I hope. Its an '89 4x4, single cab, long bed. Has a nice sThe position of the control sleeve controls at what angle the spill port opens, and thus determines the amount of fuel injected, in other words it controls the metering. The control sleeve is moved in response to a combination of accelerator position and engine speed. The latter is determined by a mechanical governor.
ix inch lift with nice big tires. Picked her up for 500$$. The only problem is the injector pump. The pulled it to fix fuel leaks. When he pulled it he didn't lock anything down. So I'm sure if anything has been moved. And not sure if it's a big deal. I have replaced leaky seals. But haven't tried to install yet. Should I be concerned about nothing being locked and with possibility things were moved. Or just go with it.
Not ure what happened there. But the crap in the middle shouldn't be there. Please disregard.
Last edited by Short cummins; May 14, 2012 at 10:19 AM. Reason: Automerged Doublepost
Old May 14, 2012 | 06:55 PM
welderboy250's Avatar
The key will line the pump up in the gear and all should be well
Old May 16, 2012 | 04:01 PM
Ok, found the problem. Heard rattles in pump. Didn't think that was good. So I opened up the back and insides exploded. I obviously need a new pump. My next ? Is, will any 1 st gen pump work, or does it have to be an 89 model only. The truck will only be used to go back and forth to work and don't wanna sink a lot $$$ into it. I thinking of locating a good used pump.
Old May 17, 2012 | 12:41 AM
1stgenblowingsmoke's Avatar
Yeah any pump will work but if you get one off a 91.5-93 you need the lines off it aswell and can't hook up the wire on the side of the pump for the cold start device which is not a big deal.
Old May 17, 2012 | 06:48 PM
tower_ofpower's Avatar
It's a good possibility when you removed the pump head the guts fell apart, not that they were already toasted. VE pumps mounted horizontally don't like gravity very much when you take them apart. The rattle you heard was probably just the governor weights movin in the cage or the slack in the governor linkage. Both noises are normal.
Old May 17, 2012 | 07:32 PM
Please explain. I've inerchanged pumps and lines before with no trouble.
Old May 18, 2012 | 08:45 PM
No there were shatters broken parts all inside.
