Water in Fuel light
Old May 13, 2012 | 11:27 AM
Curry's Avatar
Default Water in Fuel light
I have a 07 F250 6.0 and Friday on my way home from work the light came on. I drained the water fuel separator when I got home. Took it out for a long drive and the light never came back on. But today "Sunday" I went to the store and it popped back up. How often should that be drained?
Old May 13, 2012 | 12:52 PM
bobfbigman's Avatar
I always use a little carb clean and shoot it in there to get all of the water and junk out of there, if not it can take a couple of drainings.
Old May 13, 2012 | 12:59 PM
Curry's Avatar
Thanks I'll give that a shot. Will I be ok to drive it for a day with it on?
Old May 13, 2012 | 01:10 PM
bobfbigman's Avatar
its best not too, but sometimes it is just debri on the sensor.
Old May 13, 2012 | 03:37 PM
Curry's Avatar
Well I took your advice and got a can of carb cleaner and drained it again into a mason jar. Used about 1/3 of the can and decent amount of rust came out along with some water/fuel. Sprayed until it came out clean. What would of that came from? sorry if its a newbie question. (first diesel)
Old May 13, 2012 | 04:07 PM
bobfbigman's Avatar
this area of the fuel pump is the suction side so it just accumulates there, Make it a point to at least clean it out every oil change and fuel filter change. Most people only pull the plug when light comes on which is not often enough, it can hold up to 100cc of water so it can sit in there a while before light comes on .
Old May 13, 2012 | 04:18 PM
Curry's Avatar
Good to know. Thanks again I appreciate it.
Old May 31, 2013 | 07:42 AM
chappysinclair's Avatar
Default Water In Fuel
Curry,
Did you ever find a fix for this? I have drained 2 times now and let sit for an hour draining. Water in Fuel still shows up randomly. Truck runs fine so I am wondering if possible a bad sensor after 137k miles
Old May 31, 2013 | 04:41 PM
bobfbigman's Avatar
It can be just debri on the sensor, you can also remove that whole cover as long as you are carefull not to tear the gasket, it is amazing at the crud that can build up in there that doesn't come out when you do a filter change. It is a good idea to remove the whole pump/filter assembly from the frame rail and give the inside a good cleaning every now and then, maybe 50k miles is what I am doing, took it off at 250k and I was shocked at how bad the crud was in there.
Old May 31, 2013 | 04:48 PM
gunman41mag's Avatar
Moderator
I drain it every month, & clean real good every time i change the fuel filter (every 15,000 miles)
