01 5.9 24v fuel psi?
Old May 13, 2012 | 10:20 AM
hip66's Avatar
Default 01 5.9 24v fuel psi?
should there be fuel psi at the vp44 supply line when truck is off.Thanks
Old May 13, 2012 | 10:53 AM
scottywiest's Avatar
no it bleeds off, then when u turn the key and wait to start engine lite goes off ur lift pump has already supplied the IP with the amount of fuel it needs.
Fire Power's Avatar
Right after you shut it off there maybe a little pressure if you loosen the banjo bolt
Posted from my ifail when I should be working
Old May 13, 2012 | 12:27 PM
hip66's Avatar
Default thanks
thanks for the info trying to figure out hard to start problem have 16-18 psi when idling at ip'replace vp44 return check valve & washers same to help.
Old May 13, 2012 | 12:36 PM
Is it hard to start when hot?
Old May 14, 2012 | 07:39 PM
hip66's Avatar
no seems to start ok after it warms up
Old May 14, 2012 | 09:56 PM
01quadcab's Avatar
when you park it try parking it down hill and see if it starts better when cold. if it starts better then it's your cross over tube o-rings
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
J. Nick
Apr 25, 2015 05:01 PM
moneypitk5
Feb 12, 2015 11:01 AM
