how do I time a 6.9l injection pump?
Old May 12, 2012 | 11:25 PM
stubborn nut's Avatar
Default how do I time a 6.9l injection pump?
I've beem playing with the pump timing on my 86 6.9l. I here 9 or 9.5 btdc is a good number to start with? How do you go about getting there is the timing mark on the balancer at tdc or is it 7.5 or so? I'm using a Blue Point pulse adapter and the timing seems a little erratic is this poor reading on fuel line or worn injector? Also EGT's seem a little high I'm running a turbo 7psi max 4" strait pipe screw in about 1/2 flat. Will a lean condition cause high temps?
Old May 13, 2012 | 07:11 PM
DieselCrawler's Avatar
i never used a pulse adapter, i have the proper meter. i set all of them to 9.5
Old May 13, 2012 | 09:42 PM
"SmokinIDI"'s Avatar
it just depends i advanced mine from stock timing 1/16 but i also marked the stock timing so i could go back if i needed to
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
