passenger floor board wet?
Old May 12, 2012 | 08:44 PM
trentonwest29's Avatar
Default passenger floor board wet?
i have a 94 dodge ram 2500 cummins and everytime i put the floor mat in the floor gets soaked any one had this problem?
Old May 12, 2012 | 08:48 PM
Whit's Avatar
Site Mascot
yer heater core is leaking .....................its a bitch to change out to
Old May 12, 2012 | 08:49 PM
Could it be ac related?
Old May 12, 2012 | 08:59 PM
Benjamin's Avatar
Bombardier
If the evaporator core is freezing up and then defrosting at night this could be why it is wet. There should be a drain hole coming out the firewall about midway down from the cowl and midway between the center of the passenger seat. Make sure that is not plugged up. If so it will leak into the cab. Could be clogged with sludge or dirt dobbers......
Old May 12, 2012 | 09:06 PM
ducktape's Avatar
sounds like heater core leak..... its a bitch to change
Old May 12, 2012 | 09:16 PM
Whit's Avatar
Site Mascot
you will know by the smell if its glycol
Old May 12, 2012 | 10:09 PM
tiremann9669's Avatar
Could also be the windshield seal leaking
Old May 12, 2012 | 10:26 PM
12vcummins96's Avatar
mine was leaking it ended up being the a/c drain running back i siliconed up around the drain and put a hose on it
Old May 14, 2012 | 03:15 PM
1AMatt's Avatar
Site Sponsor - 1aauto
X2.... whats it smell like trentonwest29??
Old May 15, 2012 | 12:27 AM
ricet07's Avatar
My vote is widow seal.
