Horrible Knocking Noise
Old May 11, 2012 | 09:38 PM
stevieotto2's Avatar
Default Horrible Knocking Noise
So i was crusing in town about 45 mph and my truck started knocking ungodly loud and so i pulled over and shut it off. Looked to see if i blew a line or a belt or something, and everthing was in tact. From under the hood it sounded like only one cylinder was firing and you could hear the knocking hardcore threw the intake. I then had a buddy from scheid diesel driver over and take a look and see his opinion. He thinks it could be a timing problem, injectors, or valves. My guess is valves and im hoping that since i caught it quick enough it didnt mess up my pistion, Resulting in more money to get it repaired. I then had it towed to the scheid shop. Im basically asking for opinions since they said they cant look at it for 2 weeks. And kinda wanted to see if it has happened to anyone else and how much they had to spend to get it fixed?
Old May 11, 2012 | 10:16 PM
wildbill's Avatar
You got one or more injectors stuck open. Check the oil level and see if it's way over full.
Old May 12, 2012 | 12:26 PM
The oil level was fine. I just dk what to think
Old May 12, 2012 | 03:25 PM
wildbill's Avatar
Have an injector kill test done. That will isolate it to the bad cylinder, then you can go from there.
Old May 12, 2012 | 03:48 PM
Bigg Redd's Avatar
Im going to assume that your oil pressure was fine as well. It does, however, sound like an injector is kaput!
Old May 14, 2012 | 08:23 PM
Yeah my oil pressure was perfect. Maybe it is an injector? I hope cuz that means it'll be cheaper haha
Old May 16, 2012 | 07:07 AM
steved's Avatar
Oil pressure shown on the OE gauge is made up by the ECM...you cna have zero actual oil pressure before the gauge will actually show it.
When I lost my injector, the truck smoked like a freight train, and knocked badly...my oil level had never fluctuated prior to losing the injector.
Old May 18, 2012 | 10:04 PM
Bigg Redd's Avatar
Interesting
chootem
Jul 18, 2015 08:29 PM
mr. dune-a-holic
May 4, 2015 01:39 PM
Boatman
Mar 20, 2015 10:00 AM
2FordStrokers
Jan 11, 2015 09:40 PM
chaoticape
Jan 4, 2015 05:35 PM
