2001 dodge 5 to 6 speed!!
Old May 11, 2012 | 02:13 PM
slick 6 speeder's Avatar
Default 2001 dodge 5 to 6 speed!!
2001 dodge 2500 4x4 ...... This truck is currently a 5 speed 4 wheel drive ... To put a 6 speed in does the transfer case need to be changed due to the out put shaft size ??(trans to transfer case)
Old May 11, 2012 | 03:28 PM
cummin_un_glued's Avatar
FormerVendor
No they are both 29 spline so you will be fine
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old May 11, 2012 | 04:14 PM
Ok that being said it shouls be a direct swap after puting a 13 inch clutch (proper size) in the truck ....... Correct??
Old May 11, 2012 | 05:09 PM
RollinCoal99's Avatar
should be just make sure you have the right clutch
Old May 11, 2012 | 08:40 PM
welderboy250's Avatar
Be careful what input the 5600 has and u will need to do something about driveshaft length.
Old May 17, 2012 | 11:21 PM
brianell's Avatar
What he said.
Ifs it a quad cab/shortbed Ill have complete driveshafts coming out of a 6 speed truck fairly soon.
Old May 23, 2012 | 10:25 PM
scottmorgan's Avatar
be carfull i have a six speed they have a larger flywheele than the five speeds to handel more torqu you shoul be fine running the smaller fly wheele but that is a diffrence so i thought i would throughin my two cents!
Old May 24, 2012 | 09:41 AM
Rogan's Avatar
as previously mentioned, the tcase should be fine. However, the driveshafts will possibly pose problems. I've had 5 speeds with 241LD tcase that the output shaft for rear DS was too small for the driveshaft.
As for clutches, you can get the 12" clutch with the big input shaft splining, and retain your stock flywheel, but I wouldn't recommend it. Go with the 13" one for the 6speed. Don't forget that the starter may require a spacer, as well.
raude1
Apr 13, 2015 03:38 PM
wolfriver
Feb 19, 2015 07:18 AM
nelly559
Feb 2, 2015 08:19 AM
kamwil54
Nov 2, 2014 08:48 PM
Big Bill
Price Quote - Request A Price
Oct 4, 2014 04:26 PM
