Sinister coolant filter
Old May 11, 2012 | 12:11 PM
bkmac's Avatar
Default Sinister coolant filter
Has anybody had a problem with the coolant filter leaking around the seal? This is my second filter and they both leaked around the O ring.
I install them after lubricating the O ring and spin them to hand tight. Do these got installed a different way?
Old May 11, 2012 | 12:20 PM
Karls03's Avatar
Mine hasnt leaked, but I'm on my first filter. The only thing that I did differently was I didn't lube mine, I just spun it on.
Old May 11, 2012 | 01:05 PM
jimrd's Avatar
i do not think Sinister makes the filter
it was posted here ...if you search
Old May 11, 2012 | 01:56 PM
Mdub707's Avatar
Never seen one leak before... none of mine have!? I wonder if the aluminum filter housing is defective in some way?
Old May 11, 2012 | 02:38 PM
bkmac's Avatar
****** UPDATE ********
Just spoke with MKM / Sinister and explained the problem. They are sending out a new head, no charge, via 3 day UPS.
Now that is good customer service!!
Old May 11, 2012 | 02:47 PM
Mdub707's Avatar
That's good to hear! Try and compare the old to the new when it comes in and see if you can see any differences or areas it would leak.
Old May 11, 2012 | 03:02 PM
bkmac's Avatar
I asked about lubricating and they said anti freeze and also said crank it down tighter then normally done with an oil filter.
That is how I installed original Wix and thought I might have over tightened it and was supposed to have used oil.
The NAPA I lubricated with oil and hand tightened it then "snugged" a 1/4 turn or so.
We will see what happens Wed.
Old May 11, 2012 | 03:40 PM
jeffa6980's Avatar
good to hear. Mine hasnt leaked and im on my second filter.
Old May 12, 2012 | 11:39 PM
keith.tracy's Avatar
no leak here.
i smear a super thin layer of bearing grease on mine
jeffersonl
Nov 15, 2015 07:35 PM
caissiel
Sep 24, 2015 05:37 PM
Bob V
Apr 6, 2015 11:02 PM
gmcmanis
Chevy/GMC Duramax 01-04 LB7
Nov 9, 2014 04:49 PM
jeffersonl
Oct 25, 2014 06:46 AM
