98.5-02 Cummins 24V 5.9L VP-44 Tech Talk Tech Articles for the 2nd Generation Cummins 24V 5.9L VP-44 Engines.
Oil Pressure Sending Unit
Old Jul 6, 2011 | 08:17 PM
turbo20psi's Avatar
Default Oil Pressure Sending Unit
I was driving down the road 3 weeks ago or so and my oil pressure gauge was all over the place.Knowing that the oil pump in these cummins engine's are a beast,SENDING UNIT FAIL! The only oil pump fail I have seen was a marine engine with a fram filter on it..
Scanned for codes and produced a PO523=Oil Pressure Sensor High
Went to the cummins dealer and picked up a new oil pressure sender part#4921511.This part number is determined by the engine code plate that is on the side(Drivers Side) of the gear case. To take the old unit out I used a 1 1/4 inch socket to remove the sender (On the driver side under the cummins ECM). For the install the new sender was a 27mm deep.
I hope this helps out and here are some pics.
Attached Thumbnails Oil Pressure Sending Unit-100_0643.jpg   Oil Pressure Sending Unit-100_0644.jpg   Oil Pressure Sending Unit-100_0647.jpg   Oil Pressure Sending Unit-100_0644.jpg
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
jhprice
Mar 29, 2015 09:36 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
