clear smoke?
Old May 10, 2012 | 03:59 PM
Chad96Dodge's Avatar
Default clear smoke?
When i start my truck it will just smoke a real light clear to light white smoke but after it warms up it pretty much stops what could cause this? I turned my star wheel a couple turns would that mayby play a part. I have no muff its a straight pipe, I run DIESEL KLEEN as nuch as I can. any help to pin point this would be greatfull thanks
Old May 10, 2012 | 07:06 PM
welderboy250's Avatar
That would most likely be a little unburnt fuel. And no, no part of the aneroid has anything to do with the way it acts on startup.
Old May 11, 2012 | 03:33 PM
Is the Aneroid the same as the starwheel? so I should be safe with the smoke nothing to worry about just other than dirty looks when people walk thu it ha ha. Thanks for the info
Old May 11, 2012 | 07:50 PM
The star wheel u speak of is part of the aneroid assembly.
Old May 12, 2012 | 12:23 AM
9512valve's Avatar
is it cold when your starting it? i had white smoke in the fall and winter ever morning or when it sits for a few days
Old May 12, 2012 | 01:22 AM
SCHMITTY's Avatar
Mine does the same but I live in Alaska and it was 37* this morning. But it does it when it is 50+ out as well if it sits long enough so maybe it's some unburnt fuel from a cold combustion chamber that does not burn the fuel fully. We use 500,000 btu per hour diesel heaters and when they start to starve for fuel they blow white smoke
Old May 14, 2012 | 08:53 AM
I mean it really dont sit more than mabey a good long weekend its my daily driver back and fouth to work around town stuff. It sits from about 5:40 am tell 3pm and the weather is warming up. Plus I dont really remember it smoking as bad as it does no when it was winter weather. if its normal and nothing new on the ol cummins I wont worry to hard about it. I would like to figure out a way to tone it down a little if yall got some know how on that
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
gagemotors
Jun 9, 2015 04:24 AM
