Clanking from front passenger side on my DMAX
Old May 10, 2012 | 11:22 AM
GSE-DMAX's Avatar
Default Clanking from front passenger side on my DMAX
I recently purchased a 04 LB7. It has 65,000 miles on it. After I purchased it I changed the oil and greased up all the fittings first thing. Just yesterday at 68,000 miles my buddy ridding in the passenger seat noticed a clanking coming from the front on the passenger side. It's a metallic clanking sound. It sound like its coming from the wheel. I only notice it when going over speed bumps at low speeds. I haven't torn into it yet? Any suggestions? Wheel bearings? The hub? Has anyone has the same problem?
Old May 10, 2012 | 12:09 PM
2004LB7's Avatar
jack your front end up, and see if there is any play in the hub or u-joint, etc. also it may be the bolts on the front cross member (fixed by putting washers on them).
does it occur while turning hard and backing up like in a drive way?
Old May 10, 2012 | 01:23 PM
Eddiebuntain's Avatar
X2, & check out the whole front suspension, could be balljoints, shocks, etc.
Old May 10, 2012 | 02:24 PM
GSE-DMAX's Avatar
Thanks for the insight. Il let you all know what I discover. I do actually notice it when I'm turning. But again only at low speed. I'm not sure if that's cause
My trucks so loud or it goes away when I pick up speed.
Old May 11, 2012 | 08:22 PM
GSE-DMAX's Avatar
I checked it out. I can't believe it I feel sorta like a jackass. I didn't know that the hub cover was 2 pieces. The inside one was loose and rattling. I just re-sat it and it was good to go. Thanks guys for your advice though. Look forward to further discussions with y'all.
Old May 12, 2012 | 02:44 AM
That's why I don’t run hubcaps. Well, that and it's just more crap to deal with when messing with the tires.
Old May 16, 2012 | 01:19 PM
1AMatt's Avatar
Site Sponsor - 1aauto
That was an easy fix.... I wish every clunk was that easy to fix
Old May 18, 2012 | 09:26 AM
GSE-DMAX's Avatar
Yeah I agree. But if it all were that easy it wouldn't be any fun either
52deluxe
9
Mar 21, 2015 01:17 PM
jones
Feb 24, 2015 02:55 PM
