1990 p pump conversion upgrade questions
Old May 9, 2012 | 08:11 PM
peak-j's Avatar
Default 1990 p pump conversion upgrade questions
Ok, im now trying to figure out what combo to set up. I have a 1990 rotary, im doing the p pump conversion, i have the injectors out of a 1997 5.9, i want to upgrade with different nozzles, cam, turbo. Just not sure what to go with, way to many options!! The truck is a 1985 CC chevy, 4wd. It will be my daily driver, occasionally pull a toyhauler, and a lot of wood in the winter time. I would like to get to the 400-450 hp. I will do pump upgrades also. Just not sure what cam, turbo, and injector nozzles to run. I see some people are saying the spray pattern is different in the early model injectors? Just throwing this out there, but would a turbo from a 1999 24 valve get me where i want to be? I will also be installing guages!! Thanks for any help guys!!
Sent from my Motorola Electrify using Tapatalk 2
Old May 10, 2012 | 03:14 PM
wileyzreserve's Avatar
well ill be at that power range with what i added and itll be running smooth and not pieced together, nor will i have to open the motor up like at all to mess with internals, im all stock except for the add ons
Old May 10, 2012 | 03:45 PM
peak-j's Avatar
Details, rotary pump, what turbo, injectors?!!
Old May 10, 2012 | 05:36 PM
cummin_un_glued's Avatar
FormerVendor
Still havnt heard back on those injectors for ya. For 450hp i would do a 60mm turbo which there are a few options there like a 35/40 or a s300 and no bigger then a 181/210 cam and head studs. I would just tune the pump up with a modified 100 type plate 3200-4000 gsk some 191 dv's rack the barrels and put a rack plug in it while its off since you have a 180 pump then i would bench the pump after the mods to balance everything out and pin it for 16* of timing. Then a set of 90-125hp injectors. Add an airdog and a new OFV to make sure it gets plenty of fuel.
Be a fun daily driver
Sent with a Droid RAZR in one hand and 14,000 volts in the other.
Old May 10, 2012 | 10:55 PM
peak-j's Avatar
Thats fine, just let me know when you hear something from them. Thanks for the info!
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
Renteria1217
Apr 16, 2015 11:38 PM
Andrew1995
Wanted To Buy (WTB) - Used
Feb 25, 2015 03:44 PM
moneypitk5
Feb 12, 2015 11:01 AM
