need help front end vibration when i hit a bump
Old May 9, 2012 | 12:50 AM
cycloneranger's Avatar
Default need help front end vibration when i hit a bump
hi i have a 1989 dodge cummins when driveing down the road and hit a slight bump or transfer on to a bridge a mean vibration starts almost like driveing on rumble strips when i slow way down almost to a stop it will stop and no more vibration it only does this sometimes and not on all bumps i pulled front drive shaft thought this was it cause of bad u joint but i still ran into the problem please help this is getting anoying
Old May 9, 2012 | 01:07 AM
chuckles's Avatar
Jack and stands and look at everything while moving wheels. Another way would be to "get a quote" (know what I mean) at a front end shop and that way if it is real serious you are where you need to be to get it fixed.
Old May 9, 2012 | 05:31 AM
jmac5058's Avatar
Sounds like a Mopar" Death wobble " theres no one thing to fix to make all better.Try doing a search there are many threads about this.
Old May 9, 2012 | 06:09 AM
Its not a woble at all just a vibration I don't feel it in the sterling wheel at all
Old May 9, 2012 | 11:26 AM
tower_ofpower's Avatar
Bad shocks? Sounds like some mean spring oscillation.
Old May 9, 2012 | 10:21 PM
Ok so I kinda figured it out I lock my hubs in and it don't do it so what could that b?
Old May 9, 2012 | 11:39 PM
1stgenblowingsmoke's Avatar
My 90 used to do the exact same thing. I ripped both sides of the front end apart twice without a slight idea of what caused it. Repack wheel bearing reset pre load n such n she would still do it. I never did figure it out but it never got worse either. It won't be anything to do with bad shocks as this can go on for miles n miles.
I even replaced all 4 shocks to no avail, had the rear end apart with no problems in the rear wheel bearing/drums either. Rear drive shaft was good as well.
Old May 10, 2012 | 09:29 AM
Eddiebuntain's Avatar
Jack it up and check your wheel bearings. Locking in the hubs might remove enough slack to eliminate the problem. Other than that, good luck.
Also check tierod ends and balljoints, lugnuts, systematically check the whole front end.
Last edited by Eddiebuntain; May 10, 2012 at 09:29 AM. Reason: Automerged Doublepost
Old May 11, 2012 | 12:42 AM
Mine was looked over inside n out with no fix to the problem.
Old May 11, 2012 | 01:05 PM
If the truck checks out, maybe it's you. Try cutting out caffeine.
Did you break down the tires to make sure there's not a bunch of water in them? I've heard of rare cases where condensation from a compressed air line builds up 'til you get a fair amount in a tire. Rides along okay until you hit a bump just right, then it bounces around and sets off a series of vibrations. Don’t know why locking the hubs would make a difference, but if everything else checks out,it might be worth checking. Keep us posted.
Last edited by Eddiebuntain; May 11, 2012 at 01:05 PM. Reason: Automerged Doublepost
