tranny issues
Old May 8, 2012 | 07:05 PM
9512valve's Avatar
Default tranny issues
So recently ive been having problems with my tranny. its auto. if i am pushing the truck a bit hard and get to say a red light i will not shift back into 1st most the time. and when im accelerating it almost feels like a fuel cut but i lose alot of speed going into final gear. not sure if thats a good enough explanation but if anyone can understand that let me know if you have any thoughts
Old May 8, 2012 | 09:02 PM
turbo2332's Avatar
sounds like 2 gears are trying to come one at the same time??? does it pull you down for a second then shift into a higher gear an take off like nothing happened??? might do some preventitive maintenece (SP) and have everything above the valve body re-adjusted.
Old May 8, 2012 | 09:13 PM
9512valve's Avatar
ya when it does shift it just takes off. and going into the final gear it seems like it tries to down shift then nothing and i let off of the go pedal and back on it shifts
Old May 8, 2012 | 09:39 PM
turbo2332's Avatar
now that sounds like to much throttle pressure. that is the black cable that runs from your IP to the tranny. i dont remember the specs so im not gonna guess on the adjustment you can fry a tranny if it is adjusted wrong. check into that
Old May 8, 2012 | 10:33 PM
9512valve's Avatar
any way to see what of the internals to the tranny is damaged without taking the whole thing out.
Old May 9, 2012 | 07:04 AM
turbo2332's Avatar
not all of it but you can take the VB off and take a look, make sure everything is adjusted properly when your in there.
Old May 9, 2012 | 12:16 PM
9512valve's Avatar
alright ill have to see if i can get adjustments and stuff and look at it.
Old May 12, 2012 | 12:06 PM
9512valve's Avatar
ok so final gear really isnt shifting had to drive about five mins trying to get it to shift. could it be slipping?
Old May 12, 2012 | 05:37 PM
ducktape's Avatar
youd know if its slipping. i would do a fluid change and take the pan off and make sure the bands are torqued to spec while your in there. then look at sensors. dodge auto trannys are a pain to deal with hope you find the problem
dwmeehan
Jan 29, 2025 12:13 PM
wilki
Feb 12, 2015 09:04 AM
Ol' RED!
Dec 11, 2014 10:00 AM
Polaris04
Dec 1, 2014 08:27 AM
Trevlar11
Nov 16, 2014 01:59 PM
