Fuel plate
Old May 8, 2012 | 06:01 PM
cummins 12's Avatar
Default Fuel plate
Would it affect the smoke I get from my truck if I slid the stock fuel plate in the maximum fwrd possision or should I not even waste my time with it need advise from someone who knowes more about it
Old May 8, 2012 | 08:44 PM
Gotta<3a12valve's Avatar
Mine smokes but mines a ground plate all way forward
Old May 8, 2012 | 08:57 PM
turbo2332's Avatar
yes it will give you a bit more power but you will benifit much more by grinding a 100 or 0 profile.
Old May 8, 2012 | 09:37 PM
cummins 12's Avatar
So while I had it out I would be better off to just grind it down to a #0
Old May 8, 2012 | 09:40 PM
turbo2332's Avatar
or a 100, if you choose a 0 put it in the stock location. FF on a 0 is just like running without a plate.
Old May 8, 2012 | 09:50 PM
100!
Old May 8, 2012 | 11:05 PM
cummins 12's Avatar
Wat would creake the most smoke a 0 in stock possition or 100 all the way ff
Old May 8, 2012 | 11:35 PM
dieseldenny's Avatar
just take the afc housing off all together and make a block off plate or even better make a turbo delete pipe if u want smoke, if u try to make it smoke u will kill your milage and performance and prob make some big ol' egt #'s. Why not just try adding power and eventually you'l get some smoke and have something to show for it rather then a gutless doggy truck that is good for nothing but wasting expensive diesel. Also you have no signature but i would do a bhaf w/ cat and muffler delete pipes an grind your plate to a 100 ff if u plan to tow or a 0 in stock location and buy a tork teck adjustable ofv and a cheapo ebay boost elbow, you will have more power and aome smoke for a pretty low price
Old May 9, 2012 | 06:03 AM
If u r wanting to roll coal u gotta get big injectors and if ur truck is a auto put in a tc lockup switch thatll make er smoke
Old May 9, 2012 | 07:19 AM
turbo2332's Avatar
as you can probably gather most of us hate those dare i say -retarded- questions. smoke is not power. bags over the turbo = smoke a would personally grind a 100 just because there is a little more tuning you can do with it.
