no lights high or low
Old May 7, 2012 | 04:27 PM
jimrd's Avatar
Default no lights high or low
I have no lights
i have no high beam lights
i checked the fuses under the dash
they both are dead ...no power on both sides
the passing lights come on when i pull up on the turn signal lever....
i tried manualy turning headlights on using the switch
any ideas
Old May 7, 2012 | 07:09 PM
Mdub707's Avatar
Try using the tilt column and see if the lights come on at all.... probably a bad ts switch under the column, but it might just be loose.
Old May 7, 2012 | 08:06 PM
HeavyAssault's Avatar
Check the connectors....found mine burnt up when experiencing the same issues.
Old May 9, 2012 | 12:16 AM
brondondolon's Avatar
When did you notice this problem? Did it happen at random or after hard bump or rain ect? I had a very similar problem in my jeep what happened to me was water got in the compartment where all the relays were under the hood while I was off roading. I don't know if this is your problem though because I'm not sure if these trucks have a relay for the lights also when my relay went out so did my radio door locks and windows. Worth a shot though. If all else fails I'd follow the wires checking for cracks and melted wires
Old May 9, 2012 | 07:29 AM
Captainharley6.0's Avatar
Are you running super bright light bulbs, correct me if I wrong but I thought some of those super bright bulbs draw more and are hard on factory relays.....thstd why I returned mine and put regular bulbs in!!!
Sent from my GT-S5830D using Tapatalk 2
Old May 10, 2012 | 09:52 AM
jimrd's Avatar
yes using bright lights
the kit using transformers
even the high beam does not work
only pulling up on switch on column (passing)
no power on both left and right head light fuse
is there a relay for lights
Old May 10, 2012 | 10:02 AM
Mdub707's Avatar
Did you try the tilt steering? There's a switch right under the column plastic...
Old May 10, 2012 | 06:32 PM
jimrd's Avatar
so the tilt steering shuts off the lights
I have no power on both head light fusses and the high beam
both sides of the fuses are dead
i can not believe it....
I pulled the tilt steering back and bingo the high and low lights work
so i kept playing back and forth ....<<
they still work
Thank You
I guess i have to remove the sterring column plastic covers to check it out
Old May 11, 2012 | 08:20 AM
Mdub707's Avatar
Correct! It's probably just a loose connection on that switch under there. I was just reading about this, guy said he took it apart, cleaned up the connections and taped it up and it worked fine!
4x4kingx889
Sep 13, 2015 09:55 AM
robbyS
Apr 16, 2015 02:22 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
carid
Nov 10, 2014 02:15 AM
