Starting Problems ?
Old May 6, 2012 | 06:03 PM
justis's Avatar
Default Starting Problems ?
so i just recently bought a fass fuel lift pumpo for my truck becasue i had about 5psi of fuel pressure so i changed the pump and every thing was ok blead the lines and everything started up fine then a couple of days later i started getting some rough starts i have never faced this before so i dont know if its my starter or could it have to do with something on my lift pump. also ive read all around the forum that fuel pressure should be around 20 psi at idle mine is at 27-28 is there any way i could turn this down to 20 ? and is there any harmful things that could happen to my truck if i run it with 27-28 psi just need some help i dont want to mess up my truck if its just for a carless mistake thanks guys
Old May 6, 2012 | 06:16 PM
empty wallet's Avatar
High fuel pressure makes for hard starts. No advantage to running it over 20psi at idle.
Old May 6, 2012 | 06:21 PM
justis's Avatar
How do you turn it down ? If you can
Old May 6, 2012 | 07:06 PM
H.R.D's Avatar
There should be an adjustment screw on the LP.
Old May 6, 2012 | 09:55 PM
justis's Avatar
My lift pump doesn't look like that
It's just the replacement fass
Does anybody else have a idea ?
Old May 6, 2012 | 10:41 PM
farmer ford's Avatar
i was about to post a similar question because we just put a new in fueltank pickup unit with an electric fuel pump instead of just the sending unit. so now there are both the in tank pump and the pump mounted to the block. the starter cranks for 6-9 seconds before firing and the fuel pressure is at 48psi and then 60psi at idle. what do i do?
should there be fuel pressure at the pump before the key turns on? and after the truck shuts off the pressure slowly seeps down to 0psi in about 4 mins
Last edited by farmer ford; May 6, 2012 at 10:41 PM. Reason: Automerged Doublepost
Old May 7, 2012 | 07:06 AM
RAW's Avatar
RAW
Install a fuel pressure regulator:
Fass - Fuel Air Separation System
It's that simple. Then you have control over your fuel pressure.
Old May 7, 2012 | 05:21 PM
I've heard of people running high pressures to the vp accidentally but that takes the cake... holy crap
Old May 8, 2012 | 02:32 PM
FASSAshley's Avatar
Your Direct Replacement is running to high of pressure those leave our facility at 16-18 psi. The ball under the mounting bracket could be getting stuck can youtake the bracket off and look to see if the ball is stuck?
Old May 8, 2012 | 03:05 PM
justis's Avatar
Yes I could
dskewes14
Sep 14, 2015 09:19 AM
GasItOut
35
Jul 22, 2015 01:11 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
JRB1960
Dec 1, 2014 09:24 PM
angies04
Sep 29, 2014 04:11 PM
