nv4500
Old May 6, 2012 | 11:41 AM
turbolag's Avatar
Default nv4500
so i finally found a replacement tranny but its out of a 94 chevy... what would i need for it to fit my 99 ram 2500 5.9??
Old May 6, 2012 | 12:53 PM
cummin_un_glued's Avatar
FormerVendor
a 29 spline main shaft and which ever input shaft you need to fit your clutch
Old May 6, 2012 | 02:22 PM
BarryB's Avatar
The cummins had the NV4500 hd. The chevy were usually just a nv4500. The shaft size are different as well as the spline are different. Whats wrong with your current trans? Ive rebuilt a few of these, all parts can be had for them, relatively cheap. aslong as your case isn't busted. but even those can be gotten. give Pat at anahiem gear a call. He will be able to set you up with all the parts you'll need to repair your old trans. Just google their name and their website and contact info should comeup..
Old May 6, 2012 | 02:25 PM
Fire Power's Avatar
You will also need to redrill the bottom 2 bolt holes so it lines up with your bell housing There where no hd before 97 in dodge or Chevy
Old May 7, 2012 | 06:41 PM
RollinCoal99's Avatar
And you need a new output shaft to make it work
Old May 7, 2012 | 07:01 PM
Fire Power's Avatar
Output shaft is the main shaft
Posted from my ifail when I should be working
taweste
Sep 10, 2015 09:16 PM
klu408
Price Quote - Request A Price
Apr 26, 2015 07:28 PM
Robert hawkins
Feb 23, 2015 08:06 AM
dezeldoc
Wanted To Buy (WTB) - Used
Jan 4, 2015 11:12 PM
CumminsMan2.0
Dec 11, 2014 04:57 AM
