egt too high?
Old May 4, 2012 | 03:12 PM
trentowens92's Avatar
Default egt too high?
Hey if I have done some pump tuning and put a governer spring and denny t,would my egts be too high?I was gonna order gauges and the fuel pin and spring,but don't wanna waste money on the pin if I wouldn't be able to use it right now.
Old May 4, 2012 | 03:13 PM
H.R.D's Avatar
If you keep your foot out of it you will be okay. But yes if you put the pedal to the metal your EGTs will jump up.
Old May 6, 2012 | 11:37 AM
cougar's Avatar
Simply put, fuel+load=heat.
Get the gages first and watch what they do. You will soon see what causes your EGT to rise and fall. When you start making changes, keep notes. And make 1 change at a time.
Old May 13, 2012 | 08:51 AM
ok..well here in the next week or two ill be getting my egt and boost gauges to keep a eye on things.from there ill see what i gotta do.
Old May 13, 2012 | 11:15 AM
92betsy's Avatar
Look into a fuel pressure gauge also. Mine will suck the lift pump down to 0psi easy if I dig into it. Need to install my electric pump.
Old May 26, 2012 | 10:45 AM
Cummins12Club's Avatar
my egts never exceed 900 (post turbo) under full 1/4 mile passes, ive got an hx35 and about everything you can do to the pump denny t stage 2 pin and 4k gov spring included
Old Jun 2, 2012 | 10:16 AM
Gotta<3a12valve's Avatar
Im afraid mine are too high I peg a 1600 degree pyri takin off
Old Jun 3, 2012 | 05:45 PM
crewcab59's Avatar
(Cummins12club) have you turned in your fuel screw??? 900 on an hx35 at wot must not have enough fuel....even with stock injectors mine would reach 1300
Sent from my SCH-R760 using Tapatalk 2
Old Jun 5, 2012 | 03:26 PM
gregt1989's Avatar
ya 900 seems way too low. mine will hit 1750 before i let off
john grossman
10
Jan 12, 2019 08:58 PM
Blackdog15
May 20, 2015 10:49 PM
robbyS
Apr 16, 2015 02:22 PM
Brappp306
Mar 29, 2015 08:54 PM
offroad00
24
Oct 23, 2014 03:28 PM
