Heat/air won't switch from defrost..
Old May 3, 2012 | 07:42 PM
1st_gen_puller's Avatar
Default Heat/air won't switch from defrost..
ok guys my trucks heat/ac won't switch from defrost when i turn my switch... Is it my plenum.. i haven't really checked out the vacuum lines too much but it is still hooked up over by the dipstick where i've had it come loose before... thanks guys...
Old May 3, 2012 | 07:47 PM
dolla_hite's Avatar
mine did the same and it was a vacuum line. so id check again
Old May 5, 2012 | 04:49 PM
Dodgemanstan's Avatar
Mine did the same thing, it is a vaccum line in the engine compartment more than likely. Mine was on the fire wall, on the turbo side. But your leak could be anywere... Check all your little black vaccum lines and you'll find it.
Old May 5, 2012 | 05:25 PM
mrclean's Avatar
As the others stated, you have a vacuum leak. With lack of vacuum, the HVAC defaults to defrost. A very common failure point is the plastic vac line on the cruise control servo. You'll find it under the driver-side battery. Battery acid drips down directly on the line and eats a hole in it. Very hard to see, even when you are looking for it.......
Old May 8, 2012 | 07:51 AM
Alright thanks.. i'll keep looking... wonder if my chiltons would have a vacuum line diagram>???
cumminspwr11
12
Oct 17, 2021 03:50 AM
GT_Eleanor
Sep 14, 2015 10:52 AM
Ryans71
Diesel Engine Conversions
Dec 24, 2014 08:47 AM
IslanderXJ
Dec 17, 2014 04:14 PM
7.3lfordguy
8
Oct 17, 2014 11:45 PM
