Transmission heat exchanger
Old May 3, 2012 | 03:13 PM
Torkjunky's Avatar
Default Transmission heat exchanger
I am going to have to change the engine out in my 95. It started knocking the other day, I pulled the head today, I guess it spun a bearing cause #5 piston was hittng the head and you can twist it back and forth.
My questioin is do you have to run the heat exchanger. I think the purpose is the get the fluid temp up quicker. I found a motor from a 5 speed and was thinking I wold just leave it off when I change out the motors. Will it be ok or will it cause a problem with the trans. Trans has just been rebuilt.
Old May 4, 2012 | 07:59 PM
cummins3500's Avatar
No problems with mine... I have a BD trans cooler heat exchanger is MIA. U DO NOT NEED IT
Old Aug 8, 2012 | 08:41 PM
cattom's Avatar
newby here, i have a 96 and 2 99's with autos and wondering if that thing was needed.. thought about using it to heat wvo. any thoughts?
Old Aug 12, 2012 | 10:24 AM
94CTD's Avatar
IT would work for that, and trannys are a lot happier without it.
Old Aug 17, 2012 | 12:46 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Should be ok without it
auspot
Jun 30, 2015 05:57 AM
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
motormayhem
Nov 16, 2014 02:13 PM
TheDirtyDozen
Oct 1, 2014 10:09 AM
