95 cummins upgrade tips needed.
Old Apr 30, 2012 | 09:26 AM
Mike.F's Avatar
Default 95 cummins upgrade tips needed.
I have a 95 cummins 12 valve. I was just wondering if anyone could Give me some good ideas or tips to get some more horse power out of it. And in which order should I do the upgrades? Pretty much stock. Has 50k on rebuild. I think the pump is turned up alittle cause it will lay down some smoke. Has diamnond eye 4" turbo back. Cool air intake. Has nvr4500 5 speed. 410 gears with lockers. Any ideas?
Old May 2, 2012 | 09:03 PM
ducktape's Avatar
well sounds like you got the first stuff good she breathes good. next would be to turn the pump up and get a #100 plate or make one. and make sure you get a fass pump or the likes to keep the fuel pressure good. its all up to the budget you have. also are you gonna be using it as a street truck or sled truck or both?
Old May 3, 2012 | 09:46 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Gotta start with the basic stuff.... Clutch, gauges, lift pump Then you can go crazy!!
Old May 4, 2012 | 07:54 AM
Mike.F's Avatar
Mostly just everyday driving and hookin up to stock trailer. possibly tryin tug o war
Also! My fuel gauge don't read and empty gas light stays on...I went to all parts stores and the only thing they pull up is a mechanical pump...i sn't it a sending unit that reads fuel levels?
Old May 4, 2012 | 10:29 AM
1AMatt's Avatar
Yes there is a sending unit in the tank that reads how much fuel is in the tank
Old May 4, 2012 | 07:50 PM
ducktape's Avatar
where are you going to buy parts? if you dont find anything before sunday i can look it up at carquest when i go to work sunday
Old May 7, 2012 | 06:38 PM
sh13lds21's Avatar
Ide go with some 7x.010 cpp injectors, 4k gsk, and 150# cpp springs. Thats going to be my setup plus a vgt turbo off a 6.7L.
shane509
Potential Diesel Owners Forum
Sep 15, 2015 08:41 PM
mcclusk
Feb 21, 2015 09:50 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
