Lift pump
Easiest way to tell is look below the fuel filter, You will either see a pump with wires coming off of it or a silver block with no wires. Another sign is a sticker on the front clip stating a change from factory
So you should be fine with the raptor... fill out your sig so we know what you have. You need fuel pressure gauge- but you should be able to do the raptor without dropping the tank but you may run into the 1/4 tank issue.
