Before and after 4k gsk videos
Old Apr 30, 2012 | 03:29 AM
SCHMITTY's Avatar
Default Before and after 4k gsk videos
Now I need to put on the 60# springs still but I only went 1 click plus 3 more so my idle is a little lower than before but I figure it help keep from revving to high. Im very happy with it!! While I had it apart I took the time to grind the barrel on my afc, flip the washers, reset the smoke screw(it's barely touching the shaft). I also found the boost line that signals the afc was pinched. So I spliced a good piece in. The highest I could get the egts before was 1150, I bet I could bury the pyro now boost jumped up 4 psi as well. Sorry for the crappy camera work
Here is the after video.
Hopefully I have a shot at beating my coworkers 99 psd with the edge evolution programmer and mbrp 4" exhaust. I thought he had the edge juice from one of my previous posts but I was wrong.
Old May 2, 2012 | 01:50 AM
Cordova2013-12 Valve's Avatar
How hard is the gsk to install? That next on my list since I can completely fuel all the way up until the pump de-fuels instead of it tapering off like before
Old May 3, 2012 | 12:08 PM
SCHMITTY's Avatar
Not hard. I'm sure there is a writeup on the installing it. I left mine a little loose so it's only pulling to 3k or so.
Old May 3, 2012 | 01:46 PM
turbo2332's Avatar
mine are shimmed a stock washer tighter and i can only get 3600ish under a load.
