2004 Chevy 2500HD Duramax LWB
Old Apr 27, 2012 | 09:07 PM
bradenreed's Avatar
Question 2004 Chevy 2500HD Duramax LWB
Hi, all! I was wondering what your opinion is on this vehicle as a tow rig.(2004 Chevy 2500HD crewcab long box duramax LWB)
I will be using it to bumper pull a 27-30 ft. 6500-7000 lbs travel trailer. I was wondering what the specs of this engine and what my troubles would be when towing a load like this from OK to WI. Also what would MPG be? And what are the actual tow specs?
Thanks!!
Braden
Old Apr 29, 2012 | 05:21 PM
BriteWhiteRam's Avatar
well it depends on if it is an LB7 or LLY for the specs of the engine
your mileage will depend greatly on you, and a few other factors
Old May 4, 2012 | 05:30 PM
bradenreed's Avatar
It is an LLY Duramax
Old May 5, 2012 | 11:05 AM
Years offered: 2004.5-2005/ 2006 LLY is basically a de-tuned LBZ
Engine Code: LLY
8th Digit VIN Identifier: 2
Specifications:
Engine type: 6,599 cc (6.599 L; 402.7 cu in) V8 turbo
Bore x Stroke: 4.06 in (103.1 mm) x 3.90 in (99.1 mm)
Block / Head: Cast gray iron / Cast aluminum
Aspiration: Turbocharged & Intercooled
Valvetrain: OHV 4-V
Compression: 17.5:1 / 16.8:1 (2006)
Injection: Bosch High Pressure Common-rail
Power / Torque: 04.5-06; 310 HP @3000rpm / 605 LB-FT @1600 rpm.
Engine Changes from previous model:
Garrett Variable Geometry Turbocharger (VGT)
EGR Valve added
PCV now routed back through Turbo Air Intake (mouthpiece)
Redesigned Valve Covers, eliminating removal to R&R injectors and prevent fuel from pouring into crank-case
Grid Heater removed
High Idle Feature added
Early 2006 LLY model has LBZ updates including Bosch ECM and internals.
Transmission Model & Gears: Automatic: 2004.5-05; Allison 1000 5-Speed 1st-3.10 2nd-1.81 3rd-1.41 4th-1.00 5th-0.71 Rev.-4.49. 2006; Allison 1000 6-Speed 1st-3.10 2nd-1.81 3rd-1.41 4th-1.00 5th-0.71 6th-0.61 Rev.-4.49. Manual: ZF-6 ZF S6-650 6-Speed; 1st-5.79 2nd-3.31 3rd-2.10 4th-1.31 5th-1.00 6th-0.72 Rev.-5.23
Transmission Changes from previous model: None
Transfer Case: NP263XHD Electric Shift; NP261 XHD Manual
Transfer Case Changes from previous model: None
Known Motor/Transmission/Transfer Case issues:
Over-heating issues commonly reported
Restrictive mouthpiece
Injector Harness issues caused by wires rubbing against mount
Transmission overheating in cold temperatures, resolved with a TCM reflash (2006 Allison)
Transmission lines leaking at crimped couplers
Transfer Case pump rub issue due to faulty/poorly designed wear indicator retaining clip. The clip rubs a hole in the magnesium case, 246/261/263-series.
Changes to Vehicle from previous model: Higher Hood-line signifying Model Year 2005+
Known Major Vehicle Issues:
Tie-rod failure due to 4WD boosted launches or off-roading
Popular Mods:
Aftermarket intake
Programmer/Tuner/Custom Tuning
Cat-Back exhaust
Turbo-Back exhaust
LBZ/LMM/Kodiak or aftermarket mouthpiece upgrade
Resonator removal and block
PCV Re-Route
EGR Blocker Plate & Finger Stick
Race Fuel Valve
Lift Pump
Transmission Upgrades
HD Tie-rods/Sleeves
Old May 6, 2012 | 08:58 AM
bradenreed's Avatar
Oh my gosh!!! This is everytthing I needed to know! Thank you x20
Old May 6, 2012 | 09:30 AM
No problem
Old Aug 17, 2012 | 10:40 PM
bradenreed's Avatar
Default hi remember me???
Hi this is bradenreed00 again. it was a few months ago that you helped me out with some LLY specs. That wound up as a no go. I unfortunatly can't afford a duramax but I found a 1999 tahoe with the vortec 5.7L 350 I was wondering if you know how that would perform and what I would need to pull a 6000 lb. Camper i am considering now. I thought that contacting you again would be easier than searching the forum forever and not finding anything. (Already been there!)
Any help is appreciated!!
I still have high hopes!
Old Aug 23, 2012 | 11:19 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Obviously a Duramax is gonna tow a lot better. But i've driven/towed with a 5.7L Vortec and they have plenty of power!
Old Aug 24, 2012 | 10:06 PM
bradenreed's Avatar
Ok I went to look at it everything seems good. I know the KBB. It is in absolute perfect shape. Really amazing. Now I have another question. In perfect shape in your opinion what would you pay for it with 137K. 100% all options. They want 6995. How much do you think would be a good deal. (It is @ a dealer)
Thanks!!
newlywv
Chevy/GMC Duramax 06-07 LBZ
Aug 5, 2015 11:42 PM
Jul 28, 2015 12:40 PM
Mar 27, 2015 07:20 PM
Shadow644
Potential Diesel Owners Forum
Feb 5, 2015 07:48 PM
Feb 5, 2015 12:10 AM
