My 01 smokes a bit when cold
Old Apr 27, 2012 | 09:00 PM
Zukifreek's Avatar
Default My 01 smokes a bit when cold
So on my 01 Ram 2500 it smokes slightly when started cold. Just enough that you can see the blue out of the tailpipe and you can smell unburned fuel a bit. It goes away after a couple minutes. What is most likely causing this? It starts great and isn't missing or anything.
Old Apr 27, 2012 | 10:33 PM
GuyWithA24Valve's Avatar
Just a cold high mileage motor. Mine does it in the winter time and some times in the spring and fall. It's just a cold motor
Old Apr 29, 2012 | 04:14 PM
chadcycle 2500's Avatar
Don't worry mine does too
Old Apr 29, 2012 | 07:01 PM
Mr.A's Dodge Diesel's Avatar
mine too
Old Apr 30, 2012 | 01:33 AM
have you scanned for codes?
Old Apr 30, 2012 | 05:29 PM
RollinCoal99's Avatar
everyones does it when its cold.. perfectly normal
Old May 2, 2012 | 08:02 PM
holset cummins's Avatar
i have heard that when a 12v does that, you change the fuel filter and it goes away. i am not sure if this is right but it might help.
Old May 2, 2012 | 11:08 PM
wyodiesel92's Avatar
I couldn't see a 12v not smoking a little on a cold start. I've worked on a few and they all smoked a little idling cold. Not on a 60 degree ambient temp start but you get the point. Its normal. Just cold engine with unburnt fuel.
Mike0885
May 27, 2015 12:07 PM
1997silverado
Jan 23, 2015 05:06 PM
iMixDiesel&Gas
Dec 27, 2014 09:57 PM
custom7.3
Nov 24, 2014 05:16 PM
12vbomber
Nov 4, 2014 10:04 PM
