how to remove door panels to fix widow motor
Old Apr 27, 2012 | 10:51 AM
Smoknjay's Avatar
Default how to remove door panels to fix widow motor
so i need to replace my speakers in my door and have never removed a door panel before is there a simple trick to it i just dont want to break a bunch of clips or something. My power window regulator is making some f****d up sounds anyhow so im just gonna replace that aswell, the junkyard told me they have a regulator for a f250 and they think its the same does any1 know if this is true?
Old Apr 27, 2012 | 12:19 PM
Mdub707's Avatar
The panels are real easy to remove on these trucks. Grab the panel where all the switches for the windows and door locks are, just yank it up, it will pop right up. You can either unclip everything or just slide that panel down into the hole there. Pop the red reflector off on the bottom towards the latch, there is one screw behind that. I believe there is also a screw under that little panel you popped off. Then the whole thing just slides straight up and off. Really easy. You should have both sides off in less than 10 minutes, even for your first time.
