smoke smell
Old Apr 25, 2012 | 10:45 PM
guzlndzl's Avatar
Default smoke smell
whats up guys i recently installed a sinister egr delete,coolant filter kit and new oil cooler .06 f250
now that i did that i noticed that i have some smoke on start up and when i stop at light and take off ,smells like oil im wondering if the turbo seals are going bad i did oil change and new gold coolant at the time of the rest of the stuff install. and im gonna install my sct jody tune tomorrow can any one give me some insight on the cause of smoke?
smoke is on first start (cold) and when i stop at lights and take off but smokes for a couple of seconds and goes away
Old Apr 26, 2012 | 08:54 AM
Mdub707's Avatar
What color is this smoke? What kit did you install? Did it have it's own new solid up-pipe?
Old Apr 26, 2012 | 09:08 AM
guzlndzl's Avatar
It was the sinister kit with up pipe and the smoke is blueish with a little white smells like oil bigtime
So im thinking it might be turbo. Doesnt smoke when i get on it except after i stop and go
Old Apr 26, 2012 | 10:29 AM
Mdub707's Avatar
Yeah if it was a turbo it would do it all the time though.
Did you have your intake manifold hot tanked or anything? Is the EGR valve still in place? It could just be burning crud off from the install. How many miles have you put on since the job?
My guess is it's injector/FICM related though. How old are the batteries in the truck? If they're getting old, have them load tested first. If they check out, test your FICM. It's easy as pie, the instructions are at the top of the 6.0 page.
Old Apr 26, 2012 | 11:12 AM
guzlndzl's Avatar
Ok ill check the ficm i had the manifold steam cleaned and i have like 150 miles
First night i finished ran the truck smoke was pouring out for the first 50 miles then stopped i guess it was the coolant in the exhaust .
Old Apr 26, 2012 | 12:48 PM
Mdub707's Avatar
Yeah very well could have been.
Old Apr 26, 2012 | 12:51 PM
guzlndzl's Avatar
Im gonna try to take off the cat to run with out it just the dp see if smoke still comes out idk might not smoke and if it does i can eliminate that the smoke is coming from build up in muffler and cat..
Old Apr 26, 2012 | 10:27 PM
joshbaker's Avatar
Might be build up in the cat. Shoot you cant even see through the dang thing. Plus it gets better fuel millage without the cat.
Old Apr 26, 2012 | 10:33 PM
guzlndzl's Avatar
Yeah i had taken it off of my 6.0 dually couple years ago and i did see an increase in milage
So im gonna do a test pipe for now and when i need an inspection put cat on
Old Apr 27, 2012 | 09:56 AM
Mdub707's Avatar
When I took my cat off I could see clear thought it. Every taken one off of a 6.0 before? They're not exactly like a typical gas car cat. The grates inside my cat had larger openings than my grates on my propane grill.
