can I run a open thermostat
Old Apr 25, 2012 | 05:56 PM
1993firstgennewbie's Avatar
Default can I run a open thermostat
Is it ok to run a open thermostat on a cummins? My truck has never overheated it just gets hotwith the ac running.
Old Apr 25, 2012 | 06:01 PM
tiremann9669's Avatar
Whats an open thermostat Is that no tstat
Old Apr 25, 2012 | 06:08 PM
sorry no tstat I knew that was gona happen
Old Apr 25, 2012 | 06:18 PM
I guess you could if you wanted it to take forever to warm up, I'd try a new one maybe yours isn't opening all the way.
Old Apr 25, 2012 | 06:24 PM
RAW's Avatar
RAW
Without a thermostat it is not likely for it to ever warm up. The heat is needed for more then keeping you warm in the cab. The engine heat helps the engine run properly. I agree to try a new T-Stat, and see what happens.
Old Apr 25, 2012 | 09:06 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
x2 on not heating up right. i have removed t stats for some kind of problems to get home but thats it. the last truck i run that way was my 08 6.7 with a blowed head gasket.
Old Apr 25, 2012 | 10:52 PM
tower_ofpower's Avatar
You need to slow down the flow too, restrictive rings are sold and go in place of the T-stat. It let's the coolant actually pick up the heat from the cylinder walls.
Old Apr 26, 2012 | 12:19 AM
leakin 12 valve's Avatar
I ran no t stat for about 2 months i think and had no problems i pulled it out because my gauge quit working and figured better to run it cold than possibly over heat it. but mine doesn't really ever warm up even with a t stat in it unless its 90 outside.
Old Apr 26, 2012 | 10:24 PM
JeepXJ137's Avatar
Running no t stat will cause the it to overheat, because they move the coolant so fast that it doesn't stay in the rad long enough to exchange the heat.
Old Apr 27, 2012 | 03:28 PM
I've never had anything overheat from running no tstat used to do it all the time when I was young and driving beaters
