might have a problem
Old Apr 25, 2012 | 10:41 AM
cincolatham11's Avatar
Default might have a problem
so i was driving down the highway couldn't of been doing more then 55 or 60 pulling a 13 ft little toy trailer (basically) with maybe a few hundred pound load. at the beginning of the trip all was fine my truck drove like it wasnt even back there then about 25 miles from home i had cruz set going down the highway and all of the sudden the just almost died i want to say. it kicked me out of cruz and it was just a real quick jerk then i put my foot on the gas and everything was fine. except my egts they were running about 200 deg higher then normal. it threw a code and when i got back to town i shut it off when unhooking the trailer and when i started it back up the code was gone. im sure its still in there i just havent got time to check it out. it scared me a little bit so i didnt drive my truck today for fear of something bad happening like killing my IP. does anyone have any ideas on why my truck might have done that?
Old Apr 25, 2012 | 11:03 AM
GuyWithA24Valve's Avatar
What was the code? Or don't you know?
One thing you could try is disconnecting both batteries for 30 minutes. Clean up the terminals and posts on the batteries. Reconnect the batteries and reset your APPS
Old Apr 25, 2012 | 02:15 PM
How do you reset your APPS? and no i dont know the code yet i parked the truck when i got home and havent had time to really mess with it since. i am going to try to get the code this weekend.
Old Apr 25, 2012 | 04:34 PM
what fuel pressure were you running?
Old Apr 26, 2012 | 09:01 AM
vcustoms86's Avatar
Have you ever chagned your crank or cam sensors?
Old May 8, 2012 | 01:47 PM
no i have never changed the cam or crank sensor and im not sure on the fuel pressure hopefully enough.. i dont have a fuel pressure gauge yet in working on that. and i found the code its 1689 (no communication between ECM and IP). i read somewhere to try and replace my pump and horn relay and clean my grounds. im going to try that tonight or tomorrow and see what happens.(Hopefully its not my injection Pump) does anyone know what could be causing this code.
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
thurobred1320
May 5, 2015 09:26 PM
Dadslb7
Dec 9, 2014 11:05 PM
