i need a cummins mechanic. oh & sum 1 to go racing with
Old Apr 24, 2012 | 08:20 PM
ursoslw4me's Avatar
Default i need a cummins mechanic. oh & sum 1 to go racing with
Hey: i need a gr8 cummins mechanic down here in the Newport richey, Tampa area, motor only starts with starter fluid, & Turbo has no sound to it at all, even when towing About 2000 lbs. Turbo has a little play from side to side but not in & out. Truck has no gauges 4 boost, egg,fuel pressure. My dad is 84 & had some 1 work on the truck, did not run all that better when we got it bk,looking 4 the paperwork on what they did to it,but they went out of business. Any help would b greatly appreciated!! How do u get to the Badlands on here? Ill try to get on here asap when I can.. 2 c where 2 take truck.
Old Apr 25, 2012 | 12:16 AM
1stgenblowingsmoke's Avatar
Go to the main page n scroll to the bottom, you'll find the badlands there. Sounds like maybe you have a bad lift pump. These trucks will run without a lp and without the turbo so that's my guess.
Old Apr 25, 2012 | 04:55 AM
ursoslw4me's Avatar
Thanks 1stgenblowingsmoke: all I got 2 do now is find a GD cummins Mechanic down here in Tampa, Newport richey,springhill Florida area. The truck is used for towing, the racing is done with my car. Not that I wouldn't mind the truck being alot quicker though... Ttyl
Old Apr 25, 2012 | 11:59 AM
Cummins mechanic for what?
Old Apr 25, 2012 | 06:20 PM
ursoslw4me's Avatar
For my truck, I know nothing about diesels. Can't afford to do something wrong to the truck.. or I would try to fix it.
Old Apr 25, 2012 | 07:47 PM
diezeldick's Avatar
the first gen cummins are proly the easiest thing to work on aside of your lawnmower man and these guys on here will help you every step of the way
Old Apr 25, 2012 | 08:08 PM
ursoslw4me's Avatar
Yeah, seems like some very knowledgeable people on here..just would like someone to show me & tell me the rt way to do what needs to b done so I don't mess it up worse. Its hard because I do not have any gauges to see what's going on, & have no manual to refer to look at to even point me in the rt direction. I do not get much time to research after work & everything .. hopefully sum 1 knows sum 1 here in Florida close by that I can see about truck problems. & hopefully learn About the motor etc..
Old Apr 28, 2012 | 07:23 AM
Cummins12Club's Avatar
why is it that everyone who is a so call "diesel mechanic" knows absolutley nothing about these old ve 12 valves? every diesel shop in my area acts like they r so hard to work on and that the p pump is so much easier why is that?
Old Apr 28, 2012 | 08:06 AM
turbo2332's Avatar
the p pump is a 12 valve??? just a different pump, very suttle differences
Old Apr 28, 2012 | 08:54 AM
rite, but the shops were refferning to ve pump being much harder to work on than the p pumps, just talking pumps here not the engine is self
