Bad Shake
Old Apr 24, 2012 | 06:27 PM
WhiteDiesel07's Avatar
Default Bad Shake
First off, I am new to the forum.
I have been experiencing some shaking issues on hard accelerations with my newly purchased '97 Cummins. Background Info: Dually, 3" lift, #4 fuel plate, intake, exhaust, recently rebuilt auto trans.
Note: The shaking occured before rebuilding the transmission.
The shaking isn't all the time however it always happens on the interstate when I get on it running about 70. Happened for the first time not at highway speeds the other day when I got on it at about 45 and it started the same shake before it eventually shifted. Any ideas?? Is this attributed to the fuel plate?
Also I am thinking about putting the fuel plate back to stock. Recommendations?
Old Apr 24, 2012 | 07:40 PM
lunk's Avatar
u joint maybe
Old Apr 24, 2012 | 08:14 PM
ricet07's Avatar
Originally Posted by lunk
u joint maybe
x2
Old Apr 25, 2012 | 03:34 PM
But if it was the U Joint wouldn't it shake at times other than speed related?
The truck seems to shake like it can't get enough fuel. Because when it starts to shake I'll have the pedal all the way to the floor yet it won't accelerate.
Old Apr 25, 2012 | 03:37 PM
turbo2332's Avatar
check your OFV.if you have a weak spring in there to much fuel is returning to your tank and starving your pump. and since this is a WOT pretty much id def makes sence it could be fuel pressure related. can you put a guage on it and tell us what your readings are at idle and WOT???
Old Apr 26, 2012 | 11:14 AM
1AMatt's Avatar
Site Sponsor - 1aauto
If it starts shakin when your put your foot into it then it sounds like more of a fuel issue than a drive train issue to me
Old Apr 27, 2012 | 06:49 AM
Torkjunky's Avatar
I had a fuel line leaking at the fuel heater letting air into the system. Caused what sounds like the same problem.
Old Apr 27, 2012 | 06:52 PM
lodal cummins's Avatar
Converter shutter?Mine did this just in od after I installed my injectors
Old Apr 30, 2012 | 02:31 PM
1AMatt's Avatar
definitely possible. Esp if it starts at 45 mph. Thats about when the converter locks up
|WYG|SS
Jul 26, 2015 11:18 AM
|WYG|SS
Jul 4, 2015 08:31 AM
Feb 5, 2015 12:10 AM
dawnrogerl
Jan 21, 2015 09:10 AM
12vbomber
Nov 11, 2014 10:58 AM
