fuel plate adjustment
Old Apr 23, 2012 | 10:36 PM
Cummins1994's Avatar
Default fuel plate adjustment
jst ordered a #8 fuel plate and not sure which way to adjust it for more power because ive read both ways. i always thght it was away from the firewall for more power but jst read its toward it so idk u guys tell me. plz and ty
Old Apr 24, 2012 | 12:37 AM
cummin_un_glued's Avatar
FormerVendor
forward for more fuel
Old Apr 24, 2012 | 07:42 AM
thats what i thought
Old Apr 24, 2012 | 11:57 AM
cummins3500's Avatar
Yes away from the firewall.
Old Apr 24, 2012 | 01:37 PM
Cordova2013-12 Valve's Avatar
So, on the tamper proof bolt, will it break if you try to remove it if your AFC housing has never been off? Ive been told that if you just chisel a place into it for a flat head screwdriver, you can just take it right out.
Old Apr 24, 2012 | 03:07 PM
prowler48's Avatar
either that or just break it off with a chisel... or latch onto it with some vice grips
Old Apr 25, 2012 | 04:31 AM
I used a straight small pry bar and hit it with a hammer to give it a flat head indent then used my flat head impact driver and tapped it to break it loose... mine was a b**** to loosen that y i used my impact driver to shock it loose..
Old May 3, 2012 | 05:53 PM
ducktape's Avatar
make a flat head spot for it. and also slide that plate all the way to the front
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
SMatyac
Nov 15, 2014 07:35 PM
