A little help
Old Apr 23, 2012 | 10:55 AM
mossyoak54's Avatar
Default A little help
This is my first post on this forum, and i am new to it so point me in the right direction if im in the wrong spot or info is already available. I have an 01 cummins 2500. Im wanting to install a raptor pump and lines. My question is does the kit come with everything i need, and also does my truck have the in tank pump that needs removal? I am a good gas mechanic but new to diesels. Let me know what i need to get rid of factory lift pump.
Thanks.
Old Apr 23, 2012 | 12:03 PM
globalwarmingcontributor's Avatar
as far as the rapto pump, the kit comes with everything, including lines. you should check and see if u have the lift pump, its on the driver side of block, behind the fuel filter housing. thats what you will be bypassing. the raptor pump comes with all the hardware and instructions...easy install.. then pull that crappy factory lift pump off.
Old Apr 23, 2012 | 12:40 PM
mossyoak54's Avatar
Hey bud thanks for the help. I'm gonna order it today. Hopefully get it on this weekend.
Sent from the mans IPhone.
Old Apr 23, 2012 | 03:45 PM
mossyoak54's Avatar
Guys im a newbie is this my lift pump or is it in tank?
Attached Thumbnails A little help-imageuploadedbytapatalk1335213843.960431.jpg
Old Apr 23, 2012 | 04:38 PM
RAW's Avatar
RAW
That is your lift pump.
Old Apr 23, 2012 | 05:03 PM
mossyoak54's Avatar
Good deal. I ordered the pump without in tank lift pump. Thanks.
