1.25 nv5600 input, worry?
Picking up a 2000 6speed truck, 4wd. About 2 weeks before I actually get my hands on it. Betting its the smaller, non-HO 1.25 input shaft. Same input diameter as the nv4500. Is there really any concern for this?
Use of the truck will be generally pulling a light trailer, around 6k empty. Planning on turning up an edge comp box that I have, up to 300-350hp. It will periodically pull around 10k. All over the mountains. The trans will be coming off then engine anyway, as its all getting stuffed in a 99crew, dually ford. Im told the clutch has about 5k on it as well.
dont worry about it untill you do a clutch upgrade. South Bend Dual Disc clutch kit comes with billet input shaft which is required to install and is bigger and stronger than the stock 1.25
boostkid
Jun 3, 2015 11:17 AM
woodsman27
Dec 9, 2014 09:55 AM
