New dodge owner
Old Apr 22, 2012 | 08:28 PM
CoreyDyoung's Avatar
Default New dodge owner
Hey guys I've posted on here before when I had a duramax and now i am buying a 01 quad cab short box(flat bed) cummins with a 6 speed and some other fun stuff but it has 223,000 miles and it needs a new steering gear box and some other little stuff but I had a question it has 50 horse injectors, and a stock replacement turbo that pushes a little more PSI and it isnt a 53 block and the Vp44 has 20k miles on it and had a airdog 150 installed before the new pump went on and it had a little bit of an injector stumble/stutter till it gets warmed up than goes away and I was just wondering if anyone knows a good way to maybe remedy or clean the injectors since I am new to cummins I'd like to hear some stuff from a cummins guru or well anyone whos owned one cause with my duramax i had to worry about my injectors going constantly cause it well it was a LB7 but with cummins the injectors are ALOT cheaper so just wanted to hear some advice!
Thanks, Corey
Old Apr 22, 2012 | 09:32 PM
empty wallet's Avatar
Injectors are probably not dirty, but you could always clean them if you're bored I guess, probably wouldn't be a bad idea to get them pop tested and replace connector tube o-rings too while you're at it.
Old Apr 23, 2012 | 11:59 AM
globalwarmingcontributor's Avatar
i agree with empty wallet...get them pop tested
Old Apr 23, 2012 | 12:43 PM
Smarty=Cummins's Avatar
My dads 98 24 valve starts to sputter when the rpms gets over 2800 at wot so I done know Wat that would be we put injector cleaner in it. It has a brand new pump n airdog.
Old Apr 23, 2012 | 01:33 PM
RollinCoal99's Avatar
try putting power services diesel cleaner (grey bottle) every time you fill up. see what that does. suspossed to keep injectors clean
Dec 29, 2014 10:20 AM
Dec 12, 2014 12:30 PM
Dec 5, 2014 05:50 PM
Nov 16, 2014 06:10 PM
Nov 3, 2014 08:10 AM
