Prog. Question
Old Apr 22, 2012 | 09:06 AM
jfi's Avatar
jfi
Default Prog. Question
If you run tow mode on programmer. do you use your factory tow mode? Or not?
OK, guys I know it is odd question but what are you guys doing, are used still using factory tow button when towing?
Mine seems to hold gears, not shifting out until 2500rpm? When I turn tow off it shifts much better! But am I hurting transfer towing 2 horses????
Old Apr 22, 2012 | 11:43 AM
Tow Haul holds it in a lower gear longer.
Luke
Old Apr 23, 2012 | 09:22 AM
Mdub707's Avatar
Tow/haul mode does quite a few things. It will allow you to use full turbo braking too, it will also keep the converter locked more. I use an SCT with a custom tow tune, and use the tow/haul function as well. Tows amazingly well.
Forks diesel nut
Diesel Engine Conversions
Jul 27, 2015 12:19 PM
torg73
May 11, 2015 03:08 AM
99&91cummins
Mar 4, 2015 01:56 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
